11.3.2 Using the Stand-Alone QM/MM Features
11.3.2.1 $molecule section
To perform QM/MM calculations, the user must assign MM atom types for each atom in the $molecule section. The format for this specification is modeled upon that used by the Tinker molecular modeling package,812 although the Tinker program is not required to perform QM/MM calculations using Q-Chem. Force field parameters and MM atom type numbers used within Q-Chem are identical to those used Tinker for the AMBER99, CHARMM27, and OPLSAA force fields, and the format of the force field parameters files is also the same.
The $molecule section must use Cartesian coordinates to define the molecular geometry for internal QM/MM calculations; the Z-matrix format is not valid. MM atom types are specified in the $molecule section immediately after the Cartesian coordinates on a line so that the general format for the $molecule section is
  <Charge> <Multiplicity>
  <Atom> <X> <Y> <Z> <MM atom type>
   O        -0.790909    1.149780    0.907453  2001
   H        -1.628044    1.245320    1.376372  2002
   H        -0.669346    1.913705    0.331002  2002
When the input is specified as above, Q-Chem will determine the MM bond connectivity based on the distances between atoms; if two atoms are sufficiently close, they are considered to be bonded. Occasionally this approach can lead to problems when non-bonded atoms are in close proximity of one another, in which case Q-Chem might classify them as bonded regardless of whether the appropriate MM bond parameters are available. To avoid such a scenario, the user can specify the bonds explicitly by setting the $rem variable USER_CONNECT = TRUE, in which case the $molecule section must have the following format
  <Atom> <X> <Y> <Z> <MM atom type> <Bond 1> <Bond 2> <Bond 3> <Bond 4>
   O        -0.790909    1.149780    0.907453  2001  2 3 0 0
   H        -1.628044    1.245320    1.376372  2002  1 0 0 0
   H        -0.669346    1.913705    0.331002  2002  1 0 0 0
Explicitly defining the bonds in this way is highly recommended.
11.3.2.2 $force_field_params section
In many cases, all atoms types (within both the QM and MM subsystems) will be defined by a given force field. In certain cases, however, a particular atom type may not be defined in a given force field. For example, a QM/MM calculation on the propoxide anion might consist of a QM subsystem containing an alkoxide functional group, for which MM parameters do not exist. Even though the alkoxide moiety is described using quantum mechanics, van der Waals parameters are nominally required for atoms within the QM subsystem, which interact with the MM atoms via Lennard-Jones-type interactions.
  1. 1.
  2. 2.
  3. 3.
  4. 4.
    Define a new force field.
These options should be applied with care. Option 1 involves selecting an atom type that closely resembles the undefined MM atom. For example, the oxygen atom of an alkoxide moiety could perhaps use the MM atom type corresponding to the oxygen atom of a neutral hydroxyl group. Alternatively, the atom type could be ignored altogether (option 2) by specifying MM atom type 0 (zero). Setting the atom type to zero should be accompanied with setting all four explicit bond connections to placeholders if USER_CONNECT = TRUE. An atom type of zero will cause all MM energies involving that atom to be zero.
The third option in the list above requires the user to specify a $force_field_params section in the Q-Chem input file. This input section can be used to add new MM atom type definitions to one of Q-Chem’s built-in force fields. At a minimum, the user must specify the atomic charge and two Lennard-Jones parameters (radius and well depth, ϵ), for each new MM atom type. Bond, angle, and torsion parameters for stretches, bends, and torsions involving the new atom type may also be specified, if desired. The format for the $force_field_params input section is
$force_field_params
NumAtomTypes <n>
AtomType -1 <Charge> <LJ Radius> <LJ Epsilon>
AtomType -2 <Charge> <LJ Radius> <LJ Epsilon>
AtomType -n <Charge> <LJ Radius> <LJ Epsilon>
Bond <a> <b> <Force constant> <Equilibrium Distance>
Angle <a> <b> <c> <Force constant> <Equilibrium Angle>
Torsion <a> <b> <c> <d> <Force constant> <Phase Angle> <Multiplicity>
The first line in this input section specifies how many new MM atom types appear in this section (<n>). These are specified on the following lines labeled with the AtomType tag. The atom type numbers are required to be negative and to appear in the order -1,-2,-3,,-n. The $molecule section for a water molecule, with user-defined MM parameters for both oxygen and hydrogen, might appear as follows:
   O        -0.790909    1.149780    0.907453        -1  2 3 0 0
   H        -1.628044    1.245320    1.376372        -2  1 0 0 0
   H        -0.669346    1.913705    0.331002        -2  1 0 0 0
The remainder of each AtomType line in the $force_field_params section consists of a charge (in elementary charge units), a Lennard-Jones radius (in Å), and a Lennard-Jones well depth (ϵ, in kcal/mol).
Each (optional) Bond line in the $force_field_params section defines bond-stretching parameters for a bond that contains a new MM atom type. The bond may consist of both atoms <a> and <b> defined an AtomType line, or else <a> may be defined with an AtomType line and <b> defined as a regular atom type for the force field. In the latter case, the label for <b> should be the number of its general van der Waals type. For example, the atom type for a TIP3P oxygen in AMBER99 is 2001, but its van der Waals type is 21, so the latter would be specified in the Bond line. The remaining entries of each Bond line are the harmonic force constant, in kcal/mol/Å2, and the equilibrium distance, in Å.
Similar to the Bond lines, each (optional) Angle line consists of one or more new atom types along with existing van der Waals types. The central atom of the angle is <b>. The harmonic force constant (in units of kcal/mol/degree) and equilibrium bond angle (in degrees) are the final entries in each Bond line.
Each (optional) Torsion line consists of one or more new MM atom types along with regular van der Waals types. The connectivity of the four atoms that constitute the dihedral angle is <a><b><c><d>, and the torsional potential energy function is
Etorsion(θ)=ktorsion[1+cos(mθ-ϕ)] (11.36)
The force constant (ktorsion) is specified in kcal/mol and the phase angle (ϕ) in degrees. The multiplicity (m) is an integer.
11.3.2.3 User-Defined Force Fields
Option 4 in the list on page 11.3.2.2 is the most versatile, and allows the user to define a completely new force field. This option is selected by setting FORCE_FIELD = READ, which tells Q-Chem to read force field parameters from a text file whose name is specified in the $force_field_params section as follows:
$force_field_params
    Filename <path/filename>
Here, <path/filename> is the full (absolute) path and name of the file that Q-Chem will attempt to read for the MM force field. For example, if the user has a file named MyForceField.prm that resides in the path /Users/me/parameters/, then this would be specified as
$force_field_params
   Filename /Users/me/parameters/MyForceField.prm
RadiusRule <option>
EpsilonRule <option>
RadiusSize <option>
ImptorType <option>
vdw-14-scale <x>
chg-14-scale <x>
torsion-scale <x>
Currently, only a Lennard-Jones potential is available for van der Waals interactions. RadiusRule and EpsilonRule control how to average σ and ϵ, respectively, between atoms A and B in their Lennard-Jones potential. The options available for both of these rules are Arithmetic [e.g., σAB=(σA+σB)/2] or Geometric [e.g., σAB=(σAσB)1/2]. RadiusSize has options Radius or Diameter, which specify whether the parameter σ is the van der Waals radius or diameter in the Lennard-Jones potential.
NAtom <n>
Nvdw <n>
Atom 1 <Charge> <vdw Type index> <Optional description>
Atom 2 <Charge> <vdw Type index> <Optional description>
Atom <NAtom> <Charge> <vdw Type index> <Optional description>
vdw 1 <Sigma> <Epsilon> <Optional description>
vdw 2 <Sigma> <Epsilon> <Optional description>
vdw <Nvdw> <Sigma> <Epsilon> <Optional description>
Torsion <a> <b> <c> <d> <Force constant 1> <Phase Angle 1> <Multiplicity 1>
Improper <a> <b> <c> <d> <Force constant> <Equilibrium Angle> <Multiplicity>
UreyBrad <a> <b> <c>  <Force constant> <Equilibrium Distance>
EMM=ECoul+EvdW+Ebond+Eangle+Etorsion+Eimptor+EUreyBrad (11.37)
ECoul=fscaleq1q2r12 (11.38)
where q1 and q2 are the respective charges on the atoms (specified with <Charge> in elementary charge units) and r12 is the distance between the two atoms. For 1–4 pairs, fscale is defined with chg-14-scale but is unity for all other valid pairs. The van der Waals energy between two atoms with van der Waals types a and b, and separated by distance rab, is given by a “6-12” Lennard-Jones potential:
EvdW(rab)=fscaleϵab[(σabrab)12-2(σabrab)6] (11.39)
Here, fscale is the scaling factor for 1–4 interactions defined with vdw-14-scale and is unity for other valid interactions. The quantities ϵab and σab are the averages of the parameters of atoms a and b as defined with EpsilonRule and RadiusRule, respectively (see above). The units of <Sigma> are Å , and the units of <Epsilon> are kcal/mol. Hereafter, we refer to atoms’ van der Waals types with a, b, c, ... and atoms’ charges with 1,2, 3, ....
Ebond(rab)=kbond(rab-req)2 (11.40)
where kbond is provided by <Force Constant> in kcal/mol/Å2 and req by <Equilibrium Distance> in Å. Note that <a> and <b> in the Bond definition correspond to the van der Waals type indices from the vdw definitions, not the Atom indices.
Eangle(θabc)=kangle(θabc-θeq)2 (11.41)
Here, kangle is provided by <Force Constant> in kcal/mol/degrees and θeq by <Equilibrium Angle> in degrees. Again, <a>, <b>, and <c> correspond to van der Waals types defined with vdw.
Etorsion(θabcd)=fscalemkabcd[1+cos(mθabcd-ϕ)] (11.42)
Here, fscale is the scaling factor defined by torsion-scale. The force constant kabcd is defined with <Force constant> in kcal/mol, and the phase angle ϕ is defined with <Phase Angle> in degrees. The summation is over multiplicities, m, and Q-Chem supports up to three different values of m per dihedral angle. The force constants and phase angles may depend on m, so if more than one multiplicity is used, then <Force constant> <Phase Angle> <Multiplicity> should be specified for each multiplicity. For example, to specify a dihedral torsion between van der Waals types 2–1–1–2, with multiplicities m=2 and m=3, we might have:
   Torsion  2  1  1  2  2.500  180.0  2 1.500 60.0 3
Eimptor(θabcd)=kabcdNequiv[1+cos(mθabcd-ϕ)] (11.43)
Here, θabcd is the out-of-plane angle of atom <c>, in degrees, and kabcd is the force constant defined with <Force Constant>, in kcal/mol. The phase ϕ and multiplicity m need to be specified in the Improper declaration, although the definition of an improper torsion suggests that these values should be set to ϕ=0 and m=2. The quantity Nequiv accounts for the number of equivalent permutations of atoms <a>, <b>, and <d>, so that the improper torsion angle is only computed once. If ImptorType is set to Harmonic, then in place of Eq. (11.43), the following energy function is used:
Eimptor(θabcd)=kabcdNequivθabcd2 (11.44)
EUreyBrad(rac)=kabc(rac-req)2 (11.45)
The distance in Å between atoms <a> and <c> is rac, the equilibrium distance req is provided by <Equilibrium Distance> in Å, and the force constant kabc is provided by <Force Constant> in kcal/mol/Å2.
//-- Force Field Example --//
// -- Rules -- //
RadiusRule Geometric
RadiusSize Radius
EpsilonRule Geometric
ImptorType Trigonometric
vdw-14-scale 1.0
chg-14-scale 0.8
torsion-scale 0.5
// -- Number of atoms and vdw to expect -- //
NAtom 2
Nvdw 2
// -- Atoms -- //
Atom 1 -0.8340  2  TIP3P Oxygen
Atom 2  0.4170  1  TIP3P Hydrogen
// -- vdw -- //
vdw 1  0.0000  0.0000 H parameters
vdw 2  1.7682  0.1521 O parameters
// -- Bond -- //
Bond 1 2  553.0  0.9572
// -- Angle -- //
Angle 1 2 1  100.0  104.52
11.3.2.4 $qm_atoms and $forceman sections
For QM/MM calculations (but not for purely MM calculations) the user must specify the QM subsystem using a $qm_atoms input section, which assumes the following format:
$qm_atoms
   <QM atom 1 index> <QM atom 2 index> . . .
   <QM atom n index>
$qm_atoms
   18:31 35
For Janus QM/MM calculations, there are several ways of dealing with van der Waals interactions between the QM and MM atoms. By default, van der Waals interactions are computed for all QM–MM and MM–MM atom pairs but not for QM–QM atom pairs. In some cases, the user may prefer not to neglect the van der Waals interactions between QM–QM atoms, or the user may prefer to neglect any van der Waals interaction that involves a QM atom. Q-Chem allows the user this control via two options in the $forceman section. To turn on QM–QM atom van der Waals interactions, the user should include the following in their input:
$forceman
   QM-QMvdw
$forceman
   NoQM-QMorQM-MMvdw
11.3.2.5 Periodic Boundary Conditions
Periodic boundary conditions (using Ewald summation for the long-range Coulomb interactions) can be used in conjunction with both MM-only calculations and QM/MM calculations. The approach is based off of the work of Nam et al.678 and (independently) Riccardi et al.,818 as implemented in both the Amber1009 and Charmm818, 105 programs. These approaches use Mulliken charges to represent the periodic images of the wave function, and while suitable for semi-empirical calculations with minimal basis sets, instabilities in the Mulliken charges for extended basis sets lead to SCF convergence failure in the QM/MM-Ewald calculations.394 The implementation in Q-Chem thus allows for the use of ChElPG charges to represent the image wave functions, affording an algorithm that is stable in extended basis sets.394, 393
The efficiency of the Ewald summation is governed by the parameter, α, that controls the partition of the Coulomb potential into short- and long-range components, and in the QM/MM-Ewald method there are separate values of α for the QM and MM portions of the calculations. Improper selection of αMM and/or αQM can greatly increase the computational time, and the choices that are optimal for MM calculations need not be optimal for QM/MM calculations.394 The cost of the MM Ewald summation scales as 𝒪(NrecipNatoms), where Nrecip is the number of reciprocal-space lattice vectors that is used for the k-space sum. The QM portion of the calculation scales as 𝒪(NrecipNQMNatoms), where NQM is the number of QM atoms (whereas Natoms=NQM+NMM is the total number of atoms). The MM Ewald parameter is thus selected to minimize the amount of work that is done in real space. The optimal value, which is typically αMM0.5Å-1, can be found by solving the equation394
αMM=2C/L (11.46)
where
C=[-ln(10-SCF_CONVERGENCE)]1/2 (11.47)
and L is the length of the simulation cell. (Only cubic simulation cells are available at present.) In contrast, the parameter αQM should be selected to minimize the total number of vectors in both real and reciprocal space. The optimal value, which is often αQM0.1Å-1, is determined by solving the equation394
2CL3αQM3π3/2+αQM2L2π1/2-αQML-2C=0. (11.48)
  • The keyword Ewald will turn on Ewald summation.
  • The keyword alpha should be followed by a value for the MM Ewald parameter and then the QM Ewald parameter. (The latter must be set even for MM-only jobs.)
  • Box_length specifies the side length of the cubic simulation cell, in Å.
  • Dielectric specifies a dielectric constant for the surrounding medium, which appears in the “dipole term” of Ewald summation (Edipole in Ref. 394). If no value is set, the dielectric constant is set to infinity, corresponding to “tin foil" boundary conditions.
  • The keyword Ewald_SCF_thresh_on, followed by a real number, causes Q-Chem to wait until the DIIS error falls below the specified value before adding the Ewald correction to the Fock matrix, thus obviating the sometimes-costly Ewald correction in early SCF cycles. (The default value is 1.0, which turns on Ewald summation immediately in most cases)
$forceman
   ewald
   alpha                 0.35   0.1
   box_length            15.00
   dielectric            88.0
   mm_read_scratch
   ewald_scf_thresh_on   0.0001
11.3.2.6 L-BFGS for QM/MM optimization
A QM/MM geometry optimization job using L-BFGS algorithm can be requested by using the following option in the $forceman section:
$forceman
QMMM-LBFGS
The additional job controls for this job are described below. These options are also need to be specified in the $forceman section.
  • LBFGS_M: Curvature information from the last M steps will be used to construct the Hessian approximation. The default value is 10.
  • MaxSteps: Maximum number of optimization steps. The default value is 2000.
  • ConvG: Convergence on the maximun gradient components. The default tolerance value is 0.0003.
  • ConvD: Convergence on the maximum atomic displacement. The default tolerance value is 0.0012.
  • ConvE: Convergence on maximum (absolute) energy change. The default tolerance value is 0.000001.
A sample $forceman section for a QM/MM optimization job using all the above options with their default values looks like:
$forceman
QMMM-LBFGS
LBFGS_M 10
MaxSteps 2000
ConvG  0.0003
ConvD  0.0012
ConvE  0.000001
Example 11.18  QM/MM geometry optimization of water dimer using L-BFGS.
O         1.3584299158    0.1073418692   -0.2758823010   101 2 3 0 0
H         0.3884464033   -0.0182409613   -0.1252830261   88 1 0 0 0
H         1.7255084907   -0.4596377323    0.4452211001   88 1 0 0 0
O        -1.3286731559   -0.2344591932    0.1344130752   101 5 6 0 0
H        -1.7784222051    0.6341523014    0.2664866218   88 4 0 0 0
H        -1.7690342253   -0.5495694315   -0.6907120483   88 4 0 0 0
basis           sto-3g
exchange        hf
qm_mm_interface janus
force_field     charmm27
user_connect    true
jobtype         opt
no_reorient true
symmetry false
$forceman
QMMM-LBFGS
LBFGS_M 10
$qm_atoms
1 2 3
