1.3 Q-Chem Features
1.3.12 Summary of Features Prior to Q-Chem 3.0
  • Efficient algorithms for large-molecule density functional calculations:
    • CFMM for linear scaling Coulomb interactions (energies and gradients) (C. A. White).
    • Second-generation J-engine and J-force engine (Y. Shao).
    • LinK for exchange energies and forces (C. Ochsenfeld and C. A. White).
    • Linear scaling DFT exchange-correlation quadrature.
  • Local, gradient-corrected, and hybrid DFT functionals:
    • Slater, Becke, GGA91 and Gill ‘96 exchange functionals.
    • VWN, PZ81, Wigner, Perdew86, LYP and GGA91 correlation functionals.
    • EDF1 exchange-correlation functional (R. Adamson).
    • B3LYP, B3P and user-definable hybrid functionals.
    • Analytical gradients and analytical frequencies.
    • SG-0 standard quadrature grid (S.-H. Chien).
    • Lebedev grids up to 5294 points (S. T. Brown).
  • High level wave function-based electron correlation methods
    • Efficient semi-direct MP2 energies and gradients.
    • MP3, MP4, QCISD, CCSD energies.
    • OD and QCCD energies and analytical gradients.
    • Triples corrections (QCISD(T), CCSD(T) and OD(T) energies).
    • CCSD(2) and OD(2) energies.
    • Active space coupled cluster methods: VOD, VQCCD, VOD(2).
    • Local second order Møller-Plesset (MP2) methods (DIM and TRIM).
    • Improved definitions of core electrons for post-HF correlation (V. A. Rassolov).
  • Extensive excited state capabilities:
    • CIS energies, analytical gradients and analytical frequencies.
    • CIS(D) energies.
    • Time-dependent density functional theory energies (TDDFT).
    • Coupled cluster excited state energies, OD and VOD (A. I. Krylov).
    • Coupled-cluster excited-state geometry optimizations.
    • Coupled-cluster property calculations (dipoles, transition dipoles).
    • Spin-flip calculations for CCSD and TDDFT excited states (A. I. Krylov and Y. Shao).
  • High performance geometry and transition structure optimization (J. Baker):
    • Optimizes in Cartesian, Z-matrix or delocalized internal coordinates.
    • Impose bond angle, dihedral angle (torsion) or out-of-plane bend constraints.
    • Freezes atoms in Cartesian coordinates.
    • Constraints do not need to be satisfied in the starting structure.
    • Geometry optimization in the presence of fixed point charges.
    • Intrinsic reaction coordinate (IRC) following code.
  • Evaluation and visualization of molecular properties
    • Onsager, SS(V)PE and Langevin dipoles solvation models.
    • Evaluate densities, electrostatic potentials, orbitals over cubes for plotting.
    • Natural Bond Orbital (NBO) analysis.
    • Attachment/detachment densities for excited states via CIS, TDDFT.
    • Vibrational analysis after evaluation of the nuclear coordinate Hessian.
    • Isotopic substitution for frequency calculations (R. Doerksen).
    • NMR chemical shifts (J. Kussmann).
    • Atoms in Molecules (AIMPAC) support (J. Ritchie).
    • Stability analysis of SCF wave functions (Y. Shao).
    • Calculation of position and momentum molecular intracules A. Lee, N. A. Besley, and D. P. O’Neill).
  • Flexible basis set and effective core potential (ECP) functionality: (Ross Adamson and Peter Gill)
    • Wide range of built-in basis sets and ECPs.
    • Basis set superposition error correction.
    • Support for mixed and user-defined basis sets.
    • Effective core potentials for energies and gradients.
    • Highly efficient PRISM-based algorithms to evaluate ECP matrix elements.
    • Faster and more accurate ECP second derivatives for frequencies.
