7.8.23 Non-Iterative Triples Corrections to EOM-CCSD and CCSD
The effect of triple excitations to EOM-CCSD energies can be included via perturbation theory in an economical N7 computational scheme. Using EOM-CCSD wave functions as zero-order wave functions, the second order triples correction to the μth EOM-EE or SF state is:
ΔEμ(2)=-136i,j,ka,b,cσ~ijkabc(μ)σijkabc(μ)Dijkabc-ωμ (7.60)
where i,j and k denote occupied orbitals, and a,b and c are virtual orbital indices. ωμ is the EOM-CCSD excitation energy of the μth state. The quantities σ~ and σ are:
σ~ijkabc(μ) = Φ0|(L1μ+L2μ)(He(T1+T2))c|Φijkabc (7.61)
σijkabc(μ) = Φijkabc|[He(T1+T2)(R0μ+R1μ+R2μ)]c|Φ0
where, the L and R are left and right eigen-vectors for μth state. Two different choices of the denominator, Dijkabc, define the (dT) and (fT) variants of the correction. In (fT), Dijkabc is just Hartree-Fock orbital energy differences. A more accurate (but not fully orbital invariant) (dT) correction employs the complete three body diagonal of H¯, Φijkabc|(He(T1+T2))C|Φijkabc, Dijkabcas a denominator. For the reference (e.g., a ground-state CCSD wave function), the (fT) and (dT) corrections are identical to the CCSD(2)T and CR-CCSD(T)L corrections of Piecuch and coworkers.730
The EOM-SF-CCSD(dT) and EOM-SF-CCSD(fT) methods yield a systematic improvement over EOM-SF-CCSD bringing the errors below 1 kcal/mol. For theoretical background and detailed benchmarks, see Ref. 602.
Similar corrections are available for EOM-IP-CCSD,603 where triples correspond to 3h2p excitations and EOM-EA-CCSD, where triples correspond to 2h3p excitations.
Note:  Due to the orbital non-invariance problem, using (dT) correction is discouraged.
Note:  EOM-IP-CCSD(fT) correction is now available both in CCMAN and CCMAN2 .
7.8.23.1 Job Control for Non-Iterative Triples Corrections
Triples corrections are requested by using METHOD or EOM_CORR:
METHOD
       Specifies the calculation method.
       No default value
       EOM-CCSD(DT) EOM-CCSD(dT), available for EE, SF, and IP EOM-CCSD(FT) EOM-CCSD(fT), available for EE, SF, IP, and EA EOM-CCSD(ST) EOM-CCSD(sT), available for IP
EOM_CORR
       Specifies the correlation level.
       None No correction will be computed
       SD(DT) EOM-CCSD(dT), available for EE, SF, and IP SD(FT) EOM-CCSD(fT), available for EE, SF, IP, and EA SD(ST) EOM-CCSD(sT), available for IP
Note:  In CCMAN2, EOM-IP-CCSD(fT) can be computed with or without USE_LIBPT = TRUE.
7.8.23.2 Examples
Example 7.80  EOM-EE-CCSD(fT) calculation of CH+.
   C
   H  C CH
   CH  = 2.137130
   INPUT_BOHR             true
   METHOD                 eom-ccsd(ft)
   BASIS                  general
   EE_STATES              [1,0,1,1]
   EOM_DAVIDSON_MAX_ITER  60  increase number of Davidson iterations
$basis
 H   0
 S   3  1.00
       19.24060000         0.3282800000E-01
       2.899200000         0.2312080000
      0.6534000000         0.8172380000
 S   1  1.00
      0.1776000000          1.000000000
 S   1  1.00
      0.0250000000          1.000000000
 P   1  1.00
       1.00000000          1.00000000
 C   0
 S   6  1.00
       4232.610000         0.2029000000E-02
       634.8820000         0.1553500000E-01
       146.0970000         0.7541100000E-01
       42.49740000         0.2571210000
       14.18920000         0.5965550000
       1.966600000         0.2425170000
 S   1  1.00
       5.147700000          1.000000000
 S   1  1.00
      0.4962000000          1.000000000
 S   1  1.00
      0.1533000000          1.000000000
 S   1  1.00
      0.0150000000          1.000000000
 P   4  1.00
       18.15570000         0.1853400000E-01
       3.986400000         0.1154420000
       1.142900000         0.3862060000
      0.3594000000         0.6400890000
 P   1  1.00
      0.1146000000          1.000000000
 P   1  1.00
      0.0110000000          1.000000000
 D   1  1.00
      0.750000000          1.00000000
Example 7.81  EOM-SF-CCSD(dT) calculations of methylene.
   C
   H 1 CH
   H 1 CH 2 HCH
   CH  = 1.07
   HCH = 111.0
   METHOD            eom-ccsd(dt)
   BASIS             6-31G
   SF_STATES         [2,0,0,2]
   N_FROZEN_CORE     1
   N_FROZEN_VIRTUAL  1
Example 7.82  EOM-IP-CCSD(dT) calculations of Mg.
   Mg    0.000000     0.000000    0.000000
   JOBTYPE      sp
   METHOD       eom-ccsd(dt)
   BASIS        6-31g
   IP_STATES    [1,0,0,0,0,1,1,1]
