7.7 Correlated Excited State Methods: The CIS(D) Family
7.7.6 RI-CIS(D), SOS-CIS(D), and SOS-CIS(D0): Job Control
These methods are activated by setting the $rem keyword METHOD to RICIS(D), SOSCIS(D), and SOSCIS(D0), respectively. Other keywords are the same as in CIS method explained in Section 7.2.1. As these methods rely on the RI approximation, AUX_BASIS needs to be set by following the same guide as in RI-MP2 (Section 6.6).
METHOD
       Excited state method of choice
       RICIS(D) Activate RI-CIS(D) SOSCIS(D) Activate SOS-CIS(D) SOSCIS(D0) Activate SOS-CIS(D0)
CIS_N_ROOTS
       Sets the number of excited state roots to find
       0 Do not look for any excited states
       n n>0 Looks for n excited states
CIS_SINGLETS
       Solve for singlet excited states (ignored for spin unrestricted systems)
       TRUE Solve for singlet states FALSE Do not solve for singlet states.
CIS_TRIPLETS
       Solve for triplet excited states (ignored for spin unrestricted systems)
       TRUE Solve for triplet states FALSE Do not solve for triplet states.
SET_STATE_DERIV
       Sets the excited state index for analytical gradient calculation for geometry optimizations and vibrational analysis with SOS-CIS(D0)
       n Select the nth state.
       Check to see that the states do no change order during an optimization. For closed-shell systems, either CIS_SINGLETS or CIS_TRIPLETS must be set to false.
MEM_STATIC
       Sets the memory for individual program modules
       64 corresponding to 64 MB
       At least 150(N2+N)D of MEM_STATIC is required (N: number of basis functions, D: size of a double precision storage, usually 8). Because a number of matrices with N2 size also need to be stored, 32–160 MB of additional MEM_STATIC is needed.
MEM_TOTAL
       Sets the total memory available to Q-Chem
       2000 2 GB
       The minimum memory requirement of RI-CIS(D) is approximately MEM_STATIC + max(3SVXD,3X2D) (S: number of excited states, X: number of auxiliary basis functions, D: size of a double precision storage, usually 8). However, because RI-CIS(D) uses a batching scheme for efficient evaluations of electron repulsion integrals, specifying more memory will significantly speed up the calculation. Put as much memory as possible if you are not sure what to use, but never put any more than what is available. The minimum memory requirement of SOS-CIS(D) and SOS-CIS(D0) is approximately MEM_STATIC + 20X2D. SOS-CIS(D0) gradient calculation becomes more efficient when 30X2D more memory space is given. Like in RI-CIS(D), put as much memory as possible if you are not sure what to use. The actual memory size used in these calculations will be printed out in the output file to give a guide about the required memory.
SOS_FACTOR
       Sets the scaling parameter cT
       1300000 corresponding to 1.30
       n cT=n/1000000
       Use the default
SOS_UFACTOR
       Sets the scaling parameter cU
       151 For SOS-CIS(D), corresponding to 1.51 140 For SOS-CIS(D0), corresponding to 1.40
       n cU=n/100
       Use the default
