7.3.3 Job Control for TDDFT
Input for time-dependent density functional theory calculations follows very closely the input already described for the uncorrelated excited state methods described in the previous section (in particular, see Section 7.2.7). There are several points to be aware of:
  • The exchange and correlation functionals are specified exactly as for a ground state DFT calculation, through EXCHANGE and CORRELATION.
  • If RPA is set to TRUE, a “full” TDDFT calculation will be performed, however the default value is RPA = FALSE, which invokes the TDA,381 in which the de-excitation amplitudes 𝐘 in Eq. (7.15) are neglected, which is usually a good approximation for excitation energies, although oscillator strengths within the TDA no longer formally satisfy the Thomas-Reiche-Kuhn sum rule.153 For RPA = TRUE, a TDA calculation is performed first and used as the initial guess for the full TDDFT calculation. The TDA calculation can be skipped altogether using RPA = 2
  • If SPIN_FLIP is set to TRUE when performing a TDDFT calculation, a SF-DFT calculation will also be performed. At present, SF-DFT is only implemented within TDDFT/TDA so RPA must be set to FALSE. Remember to set the spin multiplicity to 3 for systems with an even-number of electrons (e.g., diradicals), and 4 for odd-number electron systems (e.g., triradicals).
TRNSS
       Controls whether reduced single excitation space is used.
       FALSE Use full excitation space.
       TRUE Use reduced excitation space.
TRTYPE
       Controls how reduced subspace is specified.
       1 Select orbitals localized on a set of atoms. 2 Specify a set of orbitals. 3 Specify a set of occupied orbitals, include excitations to all virtual orbitals.
N_SOL
       Specifies number of atoms or orbitals in the $solute section.
       No default.
       User defined.
CISTR_PRINT
       Controls level of output.
       FALSE Minimal output.
       TRUE Increase output level.
CUTOCC
       Specifies occupied orbital cutoff.
       50
       0-200 CUTOFF = CUTOCC/100
CUTVIR
       Specifies virtual orbital cutoff.
       0 No truncation
       0-100 CUTOFF = CUTVIR/100
PBHT_ANALYSIS
       Controls whether overlap analysis of electronic excitations is performed.
       FALSE Do not perform overlap analysis. TRUE Perform overlap analysis.
PBHT_FINE
       Increases accuracy of overlap analysis.
       FALSE TRUE Increase accuracy of overlap analysis.
SRC_DFT
       Selects form of the short-range corrected functional.
       No default
       1 SRC1 functional. 2 SRC2 functional.
OMEGA
       Sets the Coulomb attenuation parameter for the short-range component.
       No default
OMEGA2
       Sets the Coulomb attenuation parameter for the long-range component.
       No default
       n Corresponding to ω2=n/1000, in units of bohr-1
HF_SR
       Sets the fraction of Hartree-Fock exchange at r12=0.
       No default
       n Corresponding to HF_SR = n/1000
HF_LR
       Sets the fraction of Hartree-Fock exchange at r12=.
       No default
       n Corresponding to HF_LR = n/1000
WANG_ZIEGLER_KERNEL
       Controls whether to use the Wang-Ziegler non-collinear exchange-correlation kernel in a SF-DFT calculation.
       FALSE Do not use non-collinear kernel. TRUE Use non-collinear kernel.
