7.10 Restricted Active Space Spin-Flip (RAS-SF) and Configuration Interaction (RAS-CI)
7.10.5 Job Control for the RASCI1 Implementation
At present the RASCI1 and RASCI2 implementations employ different keywords (which will be reconciled in a future version). This subsection applies to RASCI1 (even electron systems, spin adapted algorithm using exact integrals).
The use of the RAS-CI1 methodology is controlled by setting the $rem variable CORRELATION to RASCI and EXCHANGE should be set to HF. The RASCI1 implementation is only compatible with even numbers of electrons and restricted orbitals, i.e., UNRESTRICTED = FALSE.
The minimum input also requires specifying the desired (non-zero) value for RAS_ROOTS, the number of electrons in the “active” RAS2 space and the number of orbitals in RAS1 and RAS2 subspaces.
RAS_ROOTS
       n n>0 Compute n RAS-CI states
       None. Only works with RASCI.
RAS_ELEC
       Sets the number of electrons in RAS2 (active electrons).
       n User-defined integer, n>0
RAS_ACT
       Sets the number of orbitals in RAS2 (active orbitals).
RAS_OCC
       Sets the number of orbitals in RAS1
       These are the initial doubly occupied orbitals (RAS1) before including hole type of excitations. The RAS1 space starts from the lowest orbital up to RAS_OCC, i.e. no frozen orbitals option available yet. Only works with RASCI.
RAS_DO_HOLE
       Controls the presence of hole excitations in the RAS-CI wave function.
       TRUE Include hole configurations (RAS1 to RAS2 excitations) FALSE Do not include hole configurations
RAS_DO_PART
       Controls the presence of particle excitations in the RAS-CI wave function.
       TRUE Include particle configurations (RAS2 to RAS3 excitations) FALSE Do not include particle configurations
RAS_AMPL_PRINT
       Defines the absolute threshold (×102) for the CI amplitudes to be printed.
       10 0.1 minimum absolute amplitude
       n User-defined integer, n0
RAS_ACT_ORB
       Sets the user-selected active orbitals (RAS2 orbitals).
       INTEGER ARRAY
       From RAS_OCC+1 to RAS_OCC+RAS_ACT
       [i,j,k] The number of orbitals must be equal to the RAS_ACT variable
RAS_NATORB
       Controls the computation of the natural orbital occupancies.
       TRUE Compute natural orbital occupancies for all states FALSE Do not compute natural orbital occupancies
RAS_NATORB_STATE
       Saves the natural orbitals of the i-th RASCI computed state into the .fchk file.
       i Saves the natural orbitals for the i-th state
       None. Only works with RASCI and if GUI=2.
RAS_GUESS_CS
       Controls the number of closed shell guess configurations in RAS-CI.
       n Imposes to start with n closed shell guesses
       Only relevant for the computation of singlet states. Only works with RASCI.
RAS_SPIN_MULT
       Specifies the spin multiplicity of the roots to be computed
       1 Singlet states
       0 Compute any spin multiplicity 2n+1 User-defined integer, n0
       Only for RASCI, which at present only allows for the computation of systems with an even number of electrons. Thus, RAS_SPIN_MULT only can take odd values.
RAS_PT2
       Perform second-order perturbative correction to RAS-CI energy
       TRUE Compute RASCI(2) energy corrections FALSE Do not compute RASCI(2) energy corrections
RAS_PT2_PARTITION
       Specifies the partitioning scheme in RASCI(2)
       1 Davidson-Kapuy (DK) partitioning
       2 Epstein-Nesbet (EN) partitioning 0 Do both DK and EN partitionings
       Only for RASCI if RAS_PT2 is set to true.
RAS_PT2_VSHIFT
       Defines the energy level shift (×103au) in RASCI(2)
RAS_SRDFT
       Perform short-range density functional RAS-CI calculation
       TRUE Compute RASCI-srDFT states and energies FALSE Do not perform a RASCI-srDFT calculation
       None. Only works with RASCI. RAS_SRDFT_EXC and RAS_SRDFT_COR need to be set.
RAS_SRDFT_EXC
       Define short-range exchange functional
       No default
       NAME Use RAS_SRDFT_EXC = NAME, where NAME is one of the short-range exchange functionals listed in Section 5.3.2
RAS_SRDFT_COR
       Define short-range correlation functional
       No default
       NAME Use RAS_SRDFT_COR = NAME, where NAME is one of the short-range correlation functionals listed in Section 5.3.3
RAS_OMEGA
       Sets the Coulomb range-separation parameter within the RAS-CI-srDFT method.
       400 (ω=0.4 bohr-1)
       None. Range-separation parameter is typical indicated by ω or μ. Only works with RASCI.
RAS_SRDFT_DAMP
       Sets damping factor (α<1) in the RAS-CI-srDFT method.
       REAL
       0.5 (α=0.5)
       α Damping factor 0<α<1
       Modify in case of convergence issues along the RAS-CI-srDFT iterations. Only works with RASCI
RAS_SRDFT_SA_ROOTS
       Sets the list of roots used to build the state averaged reference density in RAS-CI-srDFT.
       INTEGER ARRAY
       All computed states
       [i,j,k] List of states.
RAS_NFRAG
       If n>0 activates the excitation analysis in RASCI
       n Number of fragments to be considered
       Only for RASCI. The printed information level is controlled by RAS_PRINT
RAS_NFRAG_ATOMS
       Sets the number of atoms in each fragment.
       INTEGER ARRAY
       [i,j,k] The sum of the numbers must be equal to the total number of atoms in the systems
RAS_FRAG_SETS
       INTEGER ARRAY
       [NOcc,NAct,NVir] Number of orbitals within RAS1, RAS2 and RAS3 spaces
       [i,j,k] Defines sets of canonical MOs to be localized into n fragments
       Setting within RAS1, RAS2 and RAS3 spaces alleviates the computational cost of the localization procedure. It might also result in improved fragment orbitals. Only works with RASCI.
