6.16 Simplified Coupled-Cluster Methods Based on a Perfect-Pairing Active Space
6.16.4 Other GVBMAN Methods and Options
In Q-Chem, the unrestricted and restricted GVB methods are implemented with a resolution of the identity (RI) algorithm that makes them computationally very efficient.947, 859 They can be applied to systems with more than 100 active electrons, and both energies and analytical gradients are available. These methods are requested via the standard CORRELATION keyword. If AUX_BASIS is not specified, the calculation uses four-center two-electron integrals by default. Much faster auxiliary basis algorithms (see Section 6.6 for an introduction), which are used for the correlation energy (not the reference SCF energy), can be enabled by specifying a valid string for AUX_BASIS. The example below illustrates a simple IP calculation.
Example 6.33  Imperfect pairing with auxiliary basis set for geometry optimization.
   H
   F   1   1.0
   JOBTYPE       opt
   CORRELATION   gvb_ip
   BASIS         cc-pVDZ
   AUX_BASIS     rimp2-cc-pVDZ
If further improvement in the orbitals are needed, the GVB_SIP, GVB_DIP, OP, NP and 2P models are also included.539 The GVB_SIP model includes all the amplitudes of GVB_IP plus a set of quadratic amplitudes the represent the single ionization of a pair. The GVB_DIP model includes the GVB_SIP models amplitudes and the doubly ionized pairing amplitudes which are analogous to the correlation of the occupied electrons of the ith pair exciting into the virtual orbitals of the jth pair. These two models have the implementation limit of no analytic orbital gradient, meaning that a slow finite differences calculation must be performed to optimize their orbitals, or they must be computed using orbitals from a different method. The 2P model is the same as the GVB_DIP model, except it only allows the amplitudes to couple via integrals that span only two pairs. This allows for a fast implementation of it’s analytic orbital gradient and enables the optimization of it’s own orbitals. The OP method is like the 2P method except it removes the “direct”-like IP amplitudes and all of the same-spin amplitudes. The NP model is the GVB_IP model with the DIP amplitudes. This model is the one that works best with the symmetry breaking corrections that will be discussed later. All GVB methods except GVB_SIP and GVB_DIP have an analytic nuclear gradient implemented for both regular and RI four-center two-electron integrals.
There are often considerable challenges in converging the orbital optimization associated with these GVB-type calculations. The situation is somewhat analogous to SCF calculations but more severe because there are more orbital degrees of freedom that affect the energy (for instance, mixing occupied active orbitals amongst each other, mixing active virtual orbitals with each other, mixing core and active occupied, mixing active virtual and inactive virtual). Furthermore, the energy changes associated with many of these new orbital degrees of freedom are rather small and delicate. As a consequence, in cases where the correlations are strong, these GVB-type jobs often require many more iterations than the corresponding GDM calculations at the SCF level. This is a reflection of the correlation model itself. To deal with convergence issues, a number of REM values are available to customize the calculations, as listed below.
GVB_ORB_MAX_ITER
       Controls the number of orbital iterations allowed in GVB-CC calculations. Some jobs, particularly unrestricted PP jobs can require 500–1000 iterations.
       256
       User-defined number of iterations.
       Default is typically adequate, but some jobs, particularly UPP jobs, can require 500–1000 iterations if converged tightly.
GVB_ORB_CONV
       The GVB-CC wave function is considered converged when the root-mean-square orbital gradient and orbital step sizes are less than 10-GVB_ORB_CONV. Adjust THRESH simultaneously.
       5
       n User-defined
       Use 6 for PP(2) jobs or geometry optimizations. Tighter convergence (i.e. 7 or higher) cannot always be reliably achieved.
GVB_ORB_SCALE
       Scales the default orbital step size by n/1000.
       1000 Corresponding to 100%
           n User-defined, 0–1000
       Default is usually fine, but for some stretched geometries it can help with convergence to use smaller values.
GVB_AMP_SCALE
       Scales the default orbital amplitude iteration step size by n/1000 for IP/RCC. PP amplitude equations are solved analytically, so this parameter does not affect PP.
       Default is usually fine, but in some highly-correlated systems it can help with convergence to use smaller values.
GVB_RESTART
       Restart a job from previously-converged GVB-CC orbitals.
       TRUE/FALSE
       Useful when trying to converge to the same GVB solution at slightly different geometries, for example.
GVB_REGULARIZE
       Coefficient for GVB_IP exchange type amplitude regularization to improve the convergence of the amplitude equations especially for spin-unrestricted amplitudes near dissociation. This is the leading coefficient for an amplitude dampening term -(c/10000)(etijp-1)/(e1-1)
       0 For restricted 1 For unrestricted
       c User-defined
       Should be increased if unrestricted amplitudes do not converge or converge slowly at dissociation. Set this to zero to remove all dynamically-valued amplitude regularization.
GVB_POWER
       Coefficient for GVB_IP exchange type amplitude regularization to improve the convergence of the amplitude equations especially for spin-unrestricted amplitudes near dissociation. This is the leading coefficient for an amplitude dampening term included in the energy denominator: -(c/10000)(etijp-1)/(e1-1)
       6
       p User-defined
       Should be decreased if unrestricted amplitudes do not converge or converge slowly at dissociation, and should be kept even valued.
GVB_SHIFT
       Value for a statically valued energy shift in the energy denominator used to solve the coupled cluster amplitude equations, n/10000.
       n User-defined
       Default is fine, can be used in lieu of the dynamically valued amplitude regularization if it does not aid convergence.
Another issue that a user of these methods should be aware of is the fact that there is a multiple minimum challenge associated with GVB calculations. In SCF calculations it is sometimes possible to converge to more than one set of orbitals that satisfy the SCF equations at a given geometry. The same problem can arise in GVB calculations, and based on our experience to date, the problem in fact is more commonly encountered in GVB calculations than in SCF calculations. A user may therefore want to (or have to!) tinker with the initial guess used for the calculations. One way is to set GVB_RESTART = TRUE (see above), to replace the default initial guess (the converged SCF orbitals which are then localized). Another way is to change the localized orbitals that are used in the initial guess, which is controlled by the GVB_LOCAL variable, described below. Sometimes different localization criteria, and thus different initial guesses, lead to different converged solutions. Using the new amplitude regularization keywords enables some control over the solution GVB optimizes.538 A calculation can be performed with amplitude regularization to find a desired solution, and then the calculation can be rerun with GVB_RESTART = TRUE and the regularization turned off to remove the energy penalty of regularization.
GVB_LOCAL
       Sets the localization scheme used in the initial guess wave function.
       2 Pipek-Mezey orbitals
       0 No Localization 1 Boys localized orbitals 2 Pipek-Mezey orbitals
       Different initial guesses can sometimes lead to different solutions. It can be helpful to try both to ensure the global minimum has been found.
GVB_DO_SANO
       Sets the scheme used in determining the active virtual orbitals in a Unrestricted-in-Active Pairs GVB calculation.
       0 No localization or Sano procedure 1 Only localizes the active virtual orbitals 2 Uses the Sano procedure
       Different initial guesses can sometimes lead to different solutions. Disabling sometimes can aid in finding more non-local solutions for the orbitals.
Other $rem variables relevant to GVB calculations are given below. It is possible to explicitly set the number of active electron pairs using the GVB_N_PAIRS variable. The default is to make all valence electrons active. Other reasonable choices are certainly possible. For instance all electron pairs could be active (nactive=nβ). Or alternatively one could make only formal bonding electron pairs active (nactive=NSTO-3G-nα). Or in some cases, one might want only the most reactive electron pair to be active (nactive=1). Clearly making physically appropriate choices for this variable is essential for obtaining physically appropriate results!
GVB_N_PAIRS
       Alternative to CC_REST_OCC and CC_REST_VIR for setting active space size in GVB and valence coupled cluster methods.
       PP active space (1 occ and 1 virt for each valence electron pair)
       n user-defined
       Use the default unless one wants to study a special active space. When using small active spaces, it is important to ensure that the proper orbitals are incorporated in the active space. If not, use the $reorder_mo feature to adjust the SCF orbitals appropriately.
GVB_PRINT
       Controls the amount of information printed during a GVB-CC job.
       n User-defined
       Should never need to go above 0 or 1.
GVB_TRUNC_OCC
       Controls how many pairs’ occupied orbitals are truncated from the GVB active space.
       n User-defined
       This allows for asymmetric GVB active spaces removing the n lowest energy occupied orbitals from the GVB active space while leaving their paired virtual orbitals in the active space. Only the models including the SIP and DIP amplitudes (ie NP and 2P) benefit from this all other models this equivalent to just reducing the total number of pairs.
GVB_TRUNC_VIR
       Controls how many pairs’ virtual orbitals are truncated from the GVB active space.
       n User-defined
       This allows for asymmetric GVB active spaces removing the n highest energy occupied orbitals from the GVB active space while leaving their paired virtual orbitals in the active space. Only the models including the SIP and DIP amplitudes (ie NP and 2P) benefit from this all other models this equivalent to just reducing the total number of pairs.
GVB_REORDER_PAIRS
       Tells the code how many GVB pairs to switch around.
       n 0n5
       This allows for the user to change the order the active pairs are placed in after the orbitals are read in or are guessed using localization and the Sano procedure. Up to 5 sequential pair swaps can be made, but it is best to leave this alone.
GVB_REORDER_1
       Tells the code which two pairs to swap first.
       n User-defined XXXYYY
       This is in the format of two 3-digit pair indices that tell the code to swap pair XXX with YYY, for example swapping pair 1 and 2 would get the input 001002. Must be specified in GVB_REORDER_PAIRS 1.
GVB_REORDER_2
       Tells the code which two pairs to swap second.
       This is in the format of two 3-digit pair indices that tell the code to swap pair XXX with YYY, for example swapping pair 1 and 2 would get the input 001002. Must be specified in GVB_REORDER_PAIRS 2.
GVB_REORDER_3
       Tells the code which two pairs to swap third.
       This is in the format of two 3-digit pair indices that tell the code to swap pair XXX with YYY, for example swapping pair 1 and 2 would get the input 001002. Must be specified in GVB_REORDER_PAIRS 3.
GVB_REORDER_4
       Tells the code which two pairs to swap fourth.
       This is in the format of two 3-digit pair indices that tell the code to swap pair XXX with YYY, for example swapping pair 1 and 2 would get the input 001002. Must be specified in GVB_REORDER_PAIRS 4.
GVB_REORDER_5
       Tells the code which two pairs to swap fifth.
       This is in the format of two 3-digit pair indices that tell the code to swap pair XXX with YYY, for example swapping pair 1 and 2 would get the input 001002. Must be specified in GVB_REORDER_PAIRS 5.
It is known that symmetry breaking of the orbitals to favor localized solutions over non-local solutions is an issue with GVB methods in general. A combined coupled-cluster perturbation theory approach to solving symmetry breaking (SB) using perturbation theory level double amplitudes that connect up to three pairs has been examined in the literature,536, 537 and it seems to alleviate the SB problem to a large extent. It works in conjunction with the GVB_IP, NP, and 2P levels of correlation for both restricted and unrestricted wave functions (barring that there is no restricted implementation of the 2P model, but setting GVB_DO_ROHF to the same number as the number of pairs in the system is equivalent).
GVB_SYMFIX
       Should GVB use a symmetry breaking fix.
       0 no symmetry breaking fix 1 symmetry breaking fix with virtual orbitals spanning the active space 2 symmetry breaking fix with virtual orbitals spanning the whole virtual space
       It is best to stick with type 1 to get a symmetry breaking correction with the best results coming from CORRELATION=NP and GVB_SYMFIX = 1.
GVB_SYMPEN
       Sets the pre-factor for the amplitude regularization term for the SB amplitudes.
       160
       γ User-defined
       Sets the pre-factor for the amplitude regularization term for the SB amplitudes: -(γ/1000)(e(c*100)*t2-1).
GVB_SYMSCA
       Sets the weight for the amplitude regularization term for the SB amplitudes.
       125
       c User-defined
       Sets the weight for the amplitude regularization term for the SB amplitudes: -(γ/1000)(e(c*100)*t2-1).
We have already mentioned a few issues associated with the GVB calculations: the neglect of dynamic correlation [which can be remedied with PP(2)], the convergence challenges and the multiple minimum issues. Another weakness of these GVB methods is the occasional symmetry-breaking artifacts that are a consequence of the limited number of retained pair correlation amplitudes. For example, benzene in the PP approximation prefers D3h symmetry over D6h by 3 kcal/mol (with a 2o distortion), while in IP, this difference is reduced to 0.5 kcal/mol and less than 1o.942 Likewise the allyl radical breaks symmetry in the unrestricted PP model,81 although to a lesser extent than in restricted open shell HF. Another occasional weakness is the limitation to the perfect pairing active space, which is not necessarily appropriate for molecules with expanded valence shells, such as in some transition metal compounds (e.g. expansion from 4s3d into 4s4p3d) or possibly hyper-valent molecules (expansion from 3s3p into 3s3p3d). The singlet strongly orthogonal geminal method (see the next section) is capable of dealing with expanded valence shells and could be used for such cases. The perfect pairing active space is satisfactory for most organic and first row inorganic molecules.
To summarize, while these GVB methods are powerful and can yield much insight when used properly, they do have enough pitfalls for not to be considered true “black box” methods.
