5.3.2 Exchange Functionals
Note:  All exchange functionals in this section can be invoked using the $rem variable EXCHANGE. Popular and/or recommended functionals within each class are listed first and indicated in bold. The rest are in alphabetical order.
  • Local Spin-Density Approximation (LSDA)
    • Slater: Slater-Dirac exchange functional (Xα method with α=2/3)226
    • SR_LSDA (BNL): Short-range version of the Slater-Dirac exchange functional298
  • Generalized Gradient Approximation (GGA)
    • PBE: Perdew, Burke, and Ernzerhof exchange functional707
    • B88: Becke exchange functional from 198868
    • revPBE: Zhang and Yang one-parameter modification of the PBE exchange functional1053
    • AK13: Armiento-Kümmel exchange functional from 201340
    • B86: Becke exchange functional (Xαβγ) from 198665
    • G96: Gill exchange functional from 1996306
    • mB86: Becke “modified gradient correction” exchange functional from 198666
    • mPW91: modified version (Adamo and Barone) of the 1991 Perdew-Wang exchange functional20
    • muB88 (μB88): Short-range version of the B88 exchange functional by Hirao and coworkers408
    • muPBE (μPBE): Short-range version of the PBE exchange functional by Hirao and coworkers408
    • srPBE: Short-range version of the PBE exchange functional by Goll and coworkers318, 317
    • optB88: Refit version of the original B88 exchange functional (for use with vdW-DF-04) by Michaelides and coworkers480
    • OPTX: Two-parameter exchange functional by Handy and Cohen340
    • PBEsol: PBE exchange functional modified for solids711
    • PW86: Perdew-Wang exchange functional from 1986715
    • PW91: Perdew-Wang exchange functional from 1991708
    • RPBE: Hammer, Hansen, and Norskov exchange functional (modification of PBE)337
    • rPW86: Revised version (Murray et al.) of the 1986 Perdew-Wang exchange functional657
    • SOGGA: Second-order GGA functional by Zhao and Truhlar1061
    • wPBE (ωPBE): Henderson et al. model for the PBE GGA short-range exchange hole367
  • Meta-Generalized Gradient Approximation (meta-GGA)
    • TPSS: Tao, Perdew, Staroverov, and Scuseria exchange functional912
    • revTPSS: Revised version of the TPSS exchange functional710
    • BLOC: Minor modification of the TPSS exchange functional that works best with TPSSloc correlation (both by Della Sala and coworkers)186
    • modTPSS: One-parameter version of the TPSS exchange functional712
    • oTPSS: TPSS exchange functional with 5 refit parameters (for use with oTPSS correlation) by Grimme and coworkers313
    • PBE-GX: First exchange functional based on a finite uniform electron gas (rather than an infinite UEG) by Pierre-François Loos594
    • PKZB: Perdew, Kurth, Zupan, and Blaha exchange functional709
    • regTPSS: Regularized (fixed order of limits issue) version of the TPSS exchange functional806
    • SCAN: Strongly Constrained and Appropriately Normed exchange functional900
    • TM: Tao-Mo exchange functional derived via an accurate modeling of the conventional exchange hole911
