5.13.2 CDFT Job Control and Examples
A CDFT calculation is requested by setting CDFT = TRUE in the $rem section, as as by specifying a $cdft input section as described above. Additional job control variables are described below.
CDFT
       Initiates a constrained DFT calculation
       TRUE Perform a Constrained DFT Calculation FALSE No Density Constraint
       Set to TRUE if a Constrained DFT calculation is desired.
CDFT_POSTDIIS
       Controls whether the constraint is enforced after DIIS extrapolation.
       TRUE Enforce constraint after DIIS FALSE Do not enforce constraint after DIIS
       Use the default unless convergence problems arise, in which case it may be beneficial to experiment with setting CDFT_POSTDIIS to FALSE. With this option set to TRUE, energies should be variational after the first iteration.
CDFT_PREDIIS
       Controls whether the constraint is enforced before DIIS extrapolation.
       TRUE Enforce constraint before DIIS FALSE Do not enforce constraint before DIIS
       Use the default unless convergence problems arise, in which case it may be beneficial to experiment with setting CDFT_PREDIIS to TRUE. Note that it is possible to enforce the constraint both before and after DIIS by setting both CDFT_PREDIIS and CDFT_POSTDIIS to TRUE.
CDFT_THRESH
       Threshold that determines how tightly the constraint must be satisfied.
       5
       N Constraint is satisfied to within 10-N.
       Use the default unless problems occur.
CDFT_CRASHONFAIL
       Whether the calculation should crash or not if the constraint iterations do not converge.
       TRUE Crash if constraint iterations do not converge. FALSE Do not crash.
       Use the default.
CDFT_BECKE_POP
       Whether the calculation should print the Becke atomic charges at convergence
       TRUE Print Populations FALSE Do not print them
       Use the default. Note that the Mulliken populations printed at the end of an SCF run will not typically add up to the prescribed constraint value. Only the Becke populations are guaranteed to satisfy the user-specified constraints.
Example 5.25  Charge separation on FAAQ
   C     -0.64570736     1.37641945    -0.59867467
   C      0.64047568     1.86965826    -0.50242683
   C      1.73542663     1.01169939    -0.26307089
   C      1.48977850    -0.39245666    -0.15200261
   C      0.17444585    -0.86520769    -0.27283957
   C     -0.91002699    -0.02021483    -0.46970395
   C      3.07770780     1.57576311    -0.14660056
   C      2.57383948    -1.35303134     0.09158744
   C      3.93006075    -0.78485926     0.20164558
   C      4.16915637     0.61104948     0.08827557
   C      5.48914671     1.09087541     0.20409492
   H      5.64130588     2.16192921     0.11315072
   C      6.54456054     0.22164774     0.42486947
   C      6.30689287    -1.16262761     0.53756193
   C      5.01647654    -1.65329553     0.42726664
   H     -1.45105590     2.07404495    -0.83914389
   H      0.85607395     2.92830339    -0.61585218
   H      0.02533661    -1.93964850    -0.19096085
   H      7.55839768     0.60647405     0.51134530
   H      7.13705743    -1.84392666     0.71043613
   H      4.80090178    -2.71421422     0.50926027
   O      2.35714021    -2.57891545     0.20103599
   O      3.29128460     2.80678842    -0.23826460
   C     -2.29106231    -0.63197545    -0.53957285
   O     -2.55084900    -1.72562847    -0.95628300
   N     -3.24209015     0.26680616     0.03199109
   H     -2.81592456     1.08883943     0.45966550
   C     -4.58411403     0.11982669     0.15424004
   C     -5.28753695     1.14948617     0.86238753
   C     -5.30144592    -0.99369577    -0.39253179
   C     -6.65078185     1.06387425     1.01814801
   H     -4.73058059     1.98862544     1.26980479
   C     -6.66791492    -1.05241167    -0.21955088
   H     -4.76132422    -1.76584307    -0.92242502
   C     -7.35245187    -0.03698606     0.47966072
   H     -7.18656323     1.84034269     1.55377875
   H     -7.22179827    -1.89092743    -0.62856041
   H     -8.42896369    -0.10082875     0.60432214
   JOBTYPE         FORCE
   METHOD          B3LYP
   BASIS           6-31G*
   SCF_PRINT       TRUE
   CDFT            TRUE
$cdft
   1   1  25
  -1  26  38
Example 5.26  Cu2-Ox High Spin
   Cu      1.4674     1.6370     1.5762
   O       1.7093     0.0850     0.3825
   O      -0.5891     1.3402     0.9352
   C       0.6487    -0.3651    -0.1716
   N       1.2005     3.2680     2.7240
   N       3.0386     2.6879     0.6981
   N       1.3597     0.4651     3.4308
   H       2.1491    -0.1464     3.4851
   H       0.5184    -0.0755     3.4352
   H       1.3626     1.0836     4.2166
   H       1.9316     3.3202     3.4043
   H       0.3168     3.2079     3.1883
   H       1.2204     4.0865     2.1499
   H       3.8375     2.6565     1.2987
   H       3.2668     2.2722    -0.1823
   H       2.7652     3.6394     0.5565
   Cu     -1.4674    -1.6370    -1.5762
   O      -1.7093    -0.0850    -0.3825
   O       0.5891    -1.3402    -0.9352
   C      -0.6487     0.3651     0.1716
   N      -1.2005    -3.2680    -2.7240
   N      -3.0386    -2.6879    -0.6981
   N      -1.3597    -0.4651    -3.4308
   H      -2.6704    -3.4097    -0.1120
   H      -3.6070    -3.0961    -1.4124
   H      -3.5921    -2.0622    -0.1485
   H      -0.3622    -3.1653    -3.2595
   H      -1.9799    -3.3721    -3.3417
   H      -1.1266    -4.0773    -2.1412
   H      -0.5359     0.1017    -3.4196
   H      -2.1667     0.1211    -3.5020
   H      -1.3275    -1.0845    -4.2152
   JOBTYPE         SP
   METHOD          B3LYP
   BASIS           6-31G*
   SCF_PRINT       TRUE
   CDFT            TRUE
$cdft
   1   1   3  s
  -1  17  19  s
