Closely related to the dual-basis approach of Section 4.7, but somewhat more general, is the Hartree-Fock perturbative correction (HFPC) developed by Deng et al..217, 218 An HFPC calculation consists of an iterative HF calculation in a small primary basis followed by a single Fock matrix formation, diagonalization, and energy evaluation in a larger, secondary basis. In the following, we denote a conventional HF calculation by HF/basis, and a HFPC calculation by HFPC/primary/secondary. Using a primary basis of functions, the restricted HF matrix elements for a 2-electron system are
(4.56) |
Solving the Roothaan-Hall equation in the primary basis results in molecular orbitals and an associated density matrix, . In an HFPC calculation, is subsequently used to build a new Fock matrix, , in a larger secondary basis of functions
(4.57) |
where , indicate primary basis functions and , represent secondary basis functions. Diagonalization of affords improved molecular orbitals and an associated density matrix . The HFPC energy is given by
(4.58) |
where , , and represent secondary basis functions. This differs from the DBHF energy evaluation where , rather than , is used. The inclusion of contributions that are quadratic in is the key reason for the fact that HFPC is more accurate than DBHF.
Unlike dual-basis HF, HFPC does not require that the small basis be a proper subset of the large basis, and is therefore able to jump between any two basis sets. Benchmark study of HFPC on a large and diverse data set of total and reaction energies demonstrate that, for a range of primary/secondary basis set combinations, the HFPC scheme can reduce the error of the primary calculation by around two orders of magnitude at a cost of about one third that of the full secondary calculation.217, 218
A density-functional version of HFPC (“DFPC”)219 seeks to combine the low cost of pure DFT calculations using small bases and grids, with the high accuracy of hybrid calculations using large bases and grids. The DFPC approach is motivated by the dual-functional method of Nakajima and Hirao654 and the dual-grid scheme of Tozer et al.920 Combining these features affords a triple perturbation: to the functional, to the grid, and to the basis set. We call this approach density-functional “triple jumping”.
