13.7 The Second-Generation ALMO-EDA Method
13.7.5 Visualization Tools in EDA2
The following visualization tools are enabled in EDA2:
  • Automated generation of complementary occupied-virtual pairs (COVP)
  • Electron density difference (EDD) maps between intermediate states (FRZPOL, POLFull)
  • Plots for Natural Orbitals for Chemical Valence (NOCV)
  • Plots of frozen and polarized ALMOs
As introduced in Sec. 13.5.2, the COVPs can help elucidate the details of a charge-transfer process by showing the chemically most relevant donor-acceptor orbitals. In its implementation in EDA2, we enabled an automated selection of the most significant occupied-virtual pairs (based on a threshold on singular values). The MO cube files of these selected COVPs are then generated, and thus there is no need to specify which orbitals to plot. This new feature can be turned on by setting EDA_COVP_PRINT = AUTO. Also, both the old and new formats of the $plots section are supported for automated COVP cube generation in EDA2. The old format requires MAKE_CUBE_FILES = TRUE and the new format requires PLOTS = TRUE.
EDA2 also enabled electron density difference (EDD) plots to show the redistribution of electron density upon polarization (Δ𝐏pol=𝐏pol-𝐏frz) and charge transfer (Δ𝐏ct=𝐏full-𝐏pol). Another related quantity that can be visualized is the so-called natural orbitals for chemical valence (NOCV), 646 which are defined as the eigenvectors of Δ𝐏=𝐏full-𝐏frz. The NOCVs appear in pairs ψk and ψ-k, whose associated eigenvalues are nk and -nk, respectively. The energy lowering associated with each pair of NOCVs can be calculated using the extended transition state (ETS) approach (see ref. 646 for details). The NOCVs are useful tools for illustrating the underlying orbital interactions in chemical bonding.
In EDA2, the EDD maps are plotted when EDA_PLOT_DIFF_DEN = TRUE. The calculation of NOCVs can be turned on by EDA_NOCV = TRUE, and the most significant NOCVs are automatically selected based on a threshold on the eigenvalues {nk} and then plotted. Note that the new format of the $plots section is required for these visualizations.
Finally, in the 5.2.2 release we enabled the visualization of frozen and polarized ALMOs, which is controlled by $rem variables PLOT_ALMO_FRZ and PLOT_ALMO_POL. The user needs to specify which orbitals to plot for each fragment through the $almo_print section:
$almo_print
   frgm_idx1   orb1  orb2 ... (spin)
   frgm_idx2   orb1  orb2 ... (spin)
One can use the format “orb1:orb2" to sepcify a range of orbitals to plot for each fragment. For unrestricted cases, at the end of each line one can write “a" or “b" to specify whether alpha or beta orbitals are plotted (alpha orbitals will be plotted by default if there is no specification). As above, a $plots section with its new format is required for the visualization of ALMOs.
EDA_PLOT_DIFF_DEN
       Plot changes in electron density due to POL and CT
       FALSE Do not make EDD plots TRUE Make EDD plots
EDA_NOCV
       Perform the NOCV analysis and plot the significant NOCVs
       FALSE Do not perform NOCV analysis TRUE Perform NOCV analysis
PLOT_ALMO_FRZ
       Plot ALMOs at the frozen stage of EDA2 calculations
       FALSE Do not plot frozen ALMOs TRUE Plot frozen ALMOs
PLOT_ALMO_POL
       Plot ALMOs after the polarization calculation
       FALSE Do not plot polarized ALMOs TRUE Plot polarized ALMOs
Example 13.17  Performing perturbative CTA through EDA2 (using the default settings). The automatic COVP generation is enabled by setting EDA_PRINT_COVP = AUTO, which plots the most significant COVPs automatically. The new format of the $plots section is used by setting PLOTS = TRUE, and there is no need to specify how many orbitals to plot.
O          -1.521720    0.129941    0.000000
H          -1.924536   -0.737533    0.000000
H          -0.571766   -0.039961    0.000000
O           1.362840   -0.099704    0.000000
H           1.727645    0.357101   -0.759281
H           1.727645    0.357101    0.759281
   JOBTYPE               EDA
   METHOD                B3LYP
   BASIS                 6-31+G(d)
   SYMMETRY              FALSE
   SYM_IGNORE            FALSE
   MEM_TOTAL             8000
   MEM_STATIC            2000
   BASIS_LIN_DEP_THRESH  6
   THRESH                14
   SCF_CONVERGENCE       8
   MAXSCF                200
   EDA_COVP              TRUE
   EDA_PRINT_COVP        AUTO  !auto-generation of covp cube files
   MAKE_CUBE_FILES       TRUE
   PLOTS                 TRUE  !new format for the plot section
$plots
grid_points 100 100 100
Example 13.18  Electron density difference (EDD) plots and NOCV analysis for the NH3-BH3 complex
N         0.0000001517    0.7279666667    0.0000000000
H         0.9488005016    1.0881357449    0.0000000000
H        -0.4743994984    1.0881371276   -0.8216800000
H        -0.4743994984    1.0881371276    0.8216800000
B        -0.0000014567   -0.9275533333    0.0000000000
H        -1.1719117610   -1.2408021948    0.0000000000
H         0.5859582390   -1.2408039026   -1.0149100000
H         0.5859582390   -1.2408039026    1.0149100000
   JOBTYPE                 eda
   EDA2                    2   !ALMO-POL
   METHOD                  b3lyp
   BASIS                   6-31g(d)
   SCF_ALGORITHM           diis
   XC_GRID                 1
   SCF_CONVERGENCE         8
   MAX_SCF_CYCLES          200
   THRESH                  14
   SYMMETRY                false
   SYM_IGNORE              true
   EDA_PLOT_DIFF_DEN TRUE  !plot EDD maps
   EDA_NOCV TRUE           !plot NOCVs
$plots
Example 13.19  Plot HOMO and LUMO for each fragment (frozen and polarized ALMOs) in an EDA2 calculation
H1
O1 H1 0.95641
H2 O1 0.96500  H1 104.77306
dist = 2.0
jobtype  eda
eda2     2   !ALMO-POL
method   b3lyp
basis    6-31g
unrestricted  false
scf_algorithm  diis
scf_convergence  8
max_scf_cycles  200
thresh  14
symmetry false
sym_ignore true
plot_almo_frz true
plot_almo_pol true
$almo_print
1 5:6
2 5:6
$plots
grid_points 60 60 60
