11.10 Harmonic Vibrational Analysis
11.10.1 Job Control
In order to carry out a frequency analysis users must at a minimum provide a molecule within the $molecule keyword and define an appropriate level of theory within the $rem keyword using the $rem variables EXCHANGE, CORRELATION (if required) (Chapter 4) and BASIS (Chapter 8). Since the default type of job (JOBTYPE) is a single point energy (SP) calculation, the JOBTYPE $rem variable must be set to FREQ.
Users should also be aware that the quality of the quadrature grid used in DFT calculations is more important when calculating second derivatives. The default grid for some atoms has changed in Q-Chem 3.0 (see Section 5.5) and for this reason vibrational frequencies may vary slightly form previous versions. It is recommended that a grid larger than the default grid is used when performing frequency calculations.
  • Vibrational frequencies.
  • Raman and IR activities and intensities (requires $rem DORAMAN).
  • Atomic masses.
  • Zero-point vibrational energy.
  • Translational, rotational, and vibrational, entropies and enthalpies.
DORAMAN
       Controls calculation of Raman intensities. Requires JOBTYPE to be set to FREQ
       FALSE Do not calculate Raman intensities. TRUE Do calculate Raman intensities.
VIBMAN_PRINT
       1 Standard full information print out. If VCI is TRUE, overtones and combination bands are also printed. 3 Level 1 plus vibrational frequencies in atomic units. 4 Level 3 plus mass-weighted Hessian matrix, projected mass-weighted Hessian matrix. 6 Level 4 plus vectors for translations and rotations projection matrix.
       Use the default.
CPSCF_NSEG
       0 Do not solve the CPSCF equations in segments. n User-defined. Use n segments when solving the CPSCF equations.
       Use the default.
Example 11.17  An EDF1/6-31+G* optimization, followed by a vibrational analysis. Doing the vibrational analysis at a stationary point is necessary for the results to be valid.
   C  1  co
   F  2  fc  1  fco
   H  2  hc  1  hco  3  180.0
   co  =   1.2
   fc  =   1.4
   hc  =   1.0
   fco = 120.0
   hco = 120.0
   JOBTYPE    opt
   METHOD     edf1
   BASIS      6-31+G*
   JOBTYPE    freq
   METHOD     edf1
   BASIS      6-31+G*
